Hi all - new to forum and hoping to find some advice and suggestions. Bought a 1940 Model A tractor (SN 490470) last November - simply because I liked to tinker and thought it was cool. It sat outside for 20 years. Finally got it running about 1.5 months ago. Here's the list of work I did thus far - Changed oil and coolant, removed cleaned and reassembled brakes, cleaned/adjusted clutch and engagement mech, cleaned rust from both fuel tanks, rebuilt carb, new fuel sediment bowl and shutoff, removed and repaired missing governor fork, opened clogged oil feed hole for fan bevel gears, replaced oil slinger seal, balanced fan and rebuilt fan shaft, greased everything, rebuilt magneto, new plugs & wires, and a lot of other little things. Prior owner rebuilt cylinder head, installed new piston rings and connecting rod bearings in 2002. Once I rebuilt carb, it now starts fairly easy but I really don't have throttle control to speak of. When running it generally spins around 875 RPM. Any attempt to significantly lower the RPMs will kill it. When I rebuilt carb, I cleaned every orfice and airway with the proper sized drill bits. Float is set right. The idle screw has little effect, but load does. I am unable fully open choke and keep it running. Have to leave partially on. Should I take carb out and reclean it again? Fuel sed bowl has been pretty clean since I got it running. Any help would be appreciated. If it's possible, I'll post some pics once I better understand how forums work. Thanks in advance!
