I've had a 1946 Farmall AI here for some time. Anti-freeze in one cylinder. I expect it needs an engine and I've talked about it before. I'm limited in my abilities so am thinking of taking it to a friend capable of either fixing the engine or handling installing a replacement. Tractor has rear belt pulley. Of course this is one of the very early models with no hydraulics. So I'd be limited to spring-assist attachments unless I can add hydraulics. It would be handy if it could run a belly blade or mower, (not sickle bar). Tractor is totally complete and straight right down to starting crank and all wheel weights. Needs rear tires. I'm thinking $500 to fix motor, (lucky), to $900, (unlucky). Rear tires new, 5 to 6 hundred. Could end up with more in it than a running later A would cost.
What are the best practical uses any of you see for an early A of this type? I'd like to enjoy some light use around our 5A place and I like old tractors in the first place. Thoughts? Thanks, Dennis in E WA state
