I bought a 1956 640 off a guy on the other side of the mountain. ( ok, so it's really a hill!) I split the tractor. Replace the hydro tubes though the trans. Replaced the freeze plugs. Cleaned the water jacket in the block. Replaced the usual wear parts under the seat. Cleaned the hydro system and the rear end. Replaced the pto assembly. Rebuilt the hydro pump. Got everything going good. When I realized the lift was straining the lift arms. To the point of bending them when in the raised position! A little out of adjustment I assumed.
Unfortunately, the lift will not allow the plow to go into the ground! I bought and used Zane's instructions and gage block. And put in a new cam follower. However, it said that one of the clearances should be between 1/16" and 1/8" ? Mine measured like 5/8"? The manual says "compare old part to new known good part to see if its bent" I had no new part. But it did not look bent. I shimmed the center lift rod with a washer.
My main concern at that time was the lack of response in the hydro system. Now, the hydro system works good. But I am now going to.start work on the mechanical system again. Aside from buying all new components. What should I be looking for?
Thanks!
Joe
Thanks!
Joe
