Anonymous-0
I have a 1966 Deere 110 that the plastic cover for the shift lever is on backwards and when I take it off and turn it around it will not fit over the shifter. It is like the shifter is in the wrong position. With the cover on backwards the shifter will welect all the gears and it works ok, but I would like it to fit correctly so the shift pattern on the cover is not upside down. has anyone run into this before? Is it possible the lever is in 180 degrees off or maybe the wrong lever is in there. I bought it from a lady that was still mowing with it and said the JD dealer always worked on it.
