1966 JOHN DEERE 110
Anonymous-0
I have a 1966 Deere 110 that the plastic cover for the shift lever is on backwards and when I take it off and turn it around it will not fit over the shifter. It is like the shifter is in the wrong position. With the cover on backwards the shifter will welect all the gears and it works ok, but I would like it to fit correctly so the shift pattern on the cover is not upside down. has anyone run into this before? Is it possible the lever is in 180 degrees off or maybe the wrong lever is in there. I bought it from a lady that was still mowing with it and said the JD dealer always worked on it.
well anything is possible. that should have the shift cover that has a angle to it and 3rd and 4th gear are at the top reverse 1st and second are at the bottom. only way to tell if shifter is in wrong is take it out and see. put the tractor in neutral and take the cover off then there is 3 allen bolts holding the shifter cone on. in neutral does the shifter go at any angle or is it up and down? what is stopping the cover from going back on?
First, make sure you have the right shifter lever. You can look it up on the JD parts website. The same transaxle series was used in lots of tractors.
On the later models, there's a thick washer that goes on the boss on top of the transaxle where it bolts to the frame. If you leave it out and bolt the transaxle to the frame it will look ok at the time but the shifter won't line up with the trim plate.
