The problem:
This past week I was bush hogging, done for the day I had taken the PTO out of gear. Drove around to the front of the barn and needed to use the bush hog briefly. Pushed clutch down, felt normal, tried to move the PTO lever to engage and got grinding gears. No way would it shift. Tried four different times over a few days and does the same thing. It's as if I was not pushing the clutch down.
History:
Bought from original owner in what I would consider very good condition. Has 2,400 hours on it and from what the dealer said, the previous owner was not a farmer. Used it to move firewood and bush hog.
Ran great after a tune up. Been using it for 1.5 years.
Two stage clutch.
The transmission clutch works fine. I can go into any gear forward or reverse. Also Low and High gears.
With the tractor turned off the PTO will not shift either. I had hoped I could engage the PTO with it off and then start the tractor, provided I had nothing hooked to the PTO. Nope.
Have plenty of experience with car repairs but a slightly experienced novice with tractors.
Thanks in advance for any guidance.
History:
Two stage clutch.
