Hello, I picked up a 1979 Ford 2600 Diesel. Tractor will not start without starting fluid, once started it idles at a elevated idle (probably around 1100-1200 rpms.) Tractor runs ok, and has very strong hydraulics and will idle around with a good amount of power. However, if you try to give it any throttle it immediately dies. In low it'll run around fine but it dies in higher gears. The person I bought if from had this issue and replaced the pump and injectors and then sold it when it didn't make any difference. The pump is clocked at 0 degrees, which is where they said the last one was at. Checked all lines, pressurized the tank, changed filter and and o-rings, checked routing of fuel lines. Return to fuel tank seems to be flowing well. Not sure how to proceed, but has anyone seen anything like this? Wondering if maybe a crack in the filter housing or ? Searching online the biggest cause seems to be air ingress, but all my lines seem good. Pulled the shutoff out of the tank and it's nice and clean and flows well, pull the bleeder on the filter housing and freely flows there as well. Any suggestions or feedback would be appreciated.
