alan mc ginty (ireland)
hi all. i have a 1982 jd 3130 which i am experiencing hydraulic problems with in the back end. when i bought the tractor there was a small oil leak at the mounting pins for the rear lift arms and there was a bit of play in the power steering due to the loss of oil. i had the two seal on the mounting pins replaced, and everthing was fine for a while. because of the increased pressure from the new seals one of the seals or o rings in the steering column then started to leak. i took this to be old age and replaced it too. it has now started to leak from all three places again.
any ideas what is causing this and any solutions.
any help is greatly appreciated
