Case Nutty 1660
cnt
I had to rush this barley hay a bit for the threshing demo, it was still a bit Green in places, and the result was a couple broken bales,
the DC was on hand to help with the loading,, ended up taking 60 bales to the demo
the day of the demo was a truly Miserable day, it was 75 degrees at 7am and 98% humidity, while I was threshing it was 88-90 degrees with the same humidity and almost zero breeze,, the kind of day that you sweat just standing in shade, all in all it was a huge success for the museum, the final count was 580 people signed in and they guessed another 300 did not sign the ledger
The pounding rains and hails had again packed my summer fallow down and I had some bigger weeds getting away from me, the 1470 I had not had time to replace the turbo on yet so I hooked the 970 on the "G" series offset, I only needed to run about 2 1/2" deep in most places to cut the weeds so we got along fine
Here you can see the weed growth getting way out of hand due to it being too wet to keep things worked like I should,, it would be a couple days after this was shot by the time I got this 130 acre field worked between putting up my grain hay, I had shelled the main variable belt when the roll pin that hold the stationary driven pulley half and let things get out of alignment, the 580 was used to hold up the variable assembly to be able to change out the belt with out a whole lot of other loosening and saves me about a hour of extra non needed work, the 955 was back to laying down grain in about a hour
the same day I had a inside dual blow out on the 970,, tire was not good when I bought it and we found the PO had installed four boots already in breaks in the tire so we installed a good used extra I had on hand, I had already had the CC removed but there was a gallon or two that BLEW out when it went
my tire was a Busy at the time it blew but came early the next morning, the hyd jack was used again with Great success my tire guy loves it
Even with the hails we had to this point the grain was still making almost 2 tons per acre here, but was damaged so bad a lot of it had turned golden
