Hello, the hydraulic pump in my 1961 workbull 203 bit-it while back dragging the other day the pulley and pulley mount also broke. I took the front of the tractor apart and have the axle on a table. Ordered a new pump. Couple of questions:
How does the pump shaft that go s thru the axle come out? Does the keyed coupling that is on the pump side screw out? And how, which way?
Axle pin moves freely in the large captured housing. But where the pin passes through the axle is solid. I see no play here and bearings of captured housing seem great, no play. Should it be ok as is?
Pump shaft play in axle is pretty loose and sloppy, I believ this is correct?
