Anonymous-0
I have a problem with my hydraulic system. My pump has a squeal/shutter sound when no function is being used. You can hear it up near the front and one of the lines from the trans housing to the pump is vibrating along with the line that goes to the bottom of the reservoir in front of the raidator. When I have flow of some kind it gets quite. By flow I mean using the lift, turning the steering wheel or using the scv. I have check the standby pressure at 2250. I have cleaned sump screen, replaced filter, and changed oil. All functions work smooth and strong. I have pulled the stroke control valve and looked at it. The valve itself looks fine. I can't see the seat to tell about it. I have checked the filter bypass valve and it is also fine. I have ruled out the fact that I have a high pressure leak because the sound goes away when I use a function to let the oil flow. It sounds almost like a valve bypassing somewhere. Any ideas...This one has about gotten to me. Thanks.
