Hello, I have been on vacation for a while but i am back trying to get my 2N running, to recap my problem, i am wiring a 1941/2 2N.
Which from what i have come to realize is a custom wiring that i have inherited through a purchase, i have restored her up to this point the WIRING, when i say custom this is why, I have a MAGNETO, with a ALT, Voltage Reg, and a Starter Syilonoid, on the dash i have a toggle switch and a push button start, oil pressure and amps, so i have her turning over, oil pressure, but no spark, i have timed the MAG as i hope, i found TDC on #1cyl, adjusted the MAG at just after impulse release and secured it. BUT STILL NO SPARK, know also at this point the only WIRING i have hooked up is BATT Ground to frame and POS BATT to starter Sylonoid, starter to opposite side of starter sylonoid, small post of sylonoid to push button start and opposite side of push button switch to ground on frame. i figure after getting fire i can work on the charging system, I HOPE THIS MAKES SENSE, ANY HELP WOULD BE MOST APPRECIATED...
