Ultradog MN
- Location
- Twin Cities
Engine has the old style canister filter.
I finally got around to spinning this fresh 201 over to bleed the pump and injectors.
Have a temporary oil pressure guage hooked up.
It did not register any pressure on the guage after about 30 seconds of cranking.
So I quit.
I'm not sure how these oil systems work.
Does the oil full flow through the filter before it gets to the rest of the engine?
Does the oil pump need to fill the filter/canister from empty before you get oil pressure each time you start it?
If so, how long should that take?
I let it set for a few days afterwards - busy with other stuff.
Pulled the filter back off without draining the canister first. Lost about a cup and a half of oil down the side of the block.
Checked to be sure I had installed the coupler between the cam gear and oil pump. All good there.
What are you guy's thoughts?
So I quit.
