Paul 300 U
Hope you can help.
Starting a new thread on the conversion. I proceeded with instructions for a Hitachi alternator posted a day or two ago. I completed the wiring and attempted to start the tractor and except for some sparks at the terminals nothing happened. (Ground to negative and starter to positive) No movement on the Anmeter. No hint of cranking. Nothing.
Here is what I did.
1. I installed a 50 amp fusible link at the Bat terminal of the alternator. I tried both the 40 and 60 amp fuse the store had in stock. Neither made a difference. I will get a 50 amp asap.
2. I ran a 10 ga wire from the fusible link in step one above to the Anmeter. The positive and negative Anmeter wires are now reversed from the original 6 volt positions.
3. I ran a 12ga wire from the L terminal to the positive terminal of the new 12 volt coil.
4. I inserted a 12 volt marker light on the above wire. The light only had one wire and what appeared to me as a screw hole for mounting to metal and would therefore ground. I inserted and fastened a wire into that screw hole. When I placed one wire on the positive and the other wire on the negative posts of my 12 volt battery it worked. This was the only non LED light 12 volt light of a reasonable size from my local auto parts store.
5. I ran a 10 ga wire from the S terminal to the Bat terminal.
6. I did nothing with voltage regulator.
Hopefully it's a simple issue or something dumb I've overlooked.
Thanks. Paul
Here is what I did.
Thanks. Paul
