To Bern ,,
The moral or the story is, if you remove trumpet be careful with gasket and reuse.
Or if gasket is damaged , straight away measure thickness etc ,(dont throw in bin, Order new..
To Hobo,,
If OP's brakes are good, and he removed axle assembly from housing assembly to get access to link pin, The Inner Oil Seal is looking at him in the face, why not replace while your there ??
At least he is confident in the foreseeable future that OIL wont be seeping into brake area....
Regarding Outer Grease Seal,
If Outer seal in NOT 100% and you have replaced Inner Oil seal, I suppose grease could seep into brake area.... But you would'nt have the washout effect of oil with the grease... You could say where having a roll of the dice....
You brakes effectivness will be the judge,, And/Or check brake area for grease seep.
The alternative is ,,,.remove large nut, (you could damage the axle threads doing this), dimantle axle ,,, hub,,,re place bearing,,,Re shimming,,,etc, etc .... Unless the axle bearing is damaged or failing ,, I think I would roll the Dice on this one...
An older man has a leaky heart valve. The Doctor says you have 2 options...
1. Medication.... Your quality of life should be good.
2. Operation to replace heart valve.
Man asks what are the negatives of both...
Medication ... None, but we will have to see you every 12 months for checkup.
Operation ... If successful you will have a heart like a 40 year old.... But there is a 70% chance the operation will kill you..
Talk about having a throw of the dice ....
This post was edited by markwolumla on 10/01/2023 at 07:50 pm.
