onetotaltoolman
Ok - the overhaul on the free (hah) D14 continues. Done with the power steering overhaul, clutch work and seals. Now just about time to
re-join the halves and put the front axle/wheel assembly back in. One other problem that should be addressed before finishing this . The pivot pin on the front
axle (where it enters the front support to steady the front axle) is heavily worn from rotation in the front support. The front support is also egg shaped from
wear as well. Interesting that AGCO still actually sells a new pivot pin that could be welded on the front axle (i'll have to be nice to Santa for this one- it's
about $300.00). There is also a bushing that AGCO sells that shows going in the front support. I'll assume the engineers figured out how much stress and
rotational wear these non-lubed pieces were getting. So, anyone have a great fix. What I've done so far is drill and tap the front support to be able to add
grease. With no shroud on the pivot point, that will attract dirt, but i think the best of two evils. I'm considering using my mig to build weld material on the
pin, then re-shape it with a flap disk or grinder. I can't see spending 300 bucks for a new pin, and maybe it's worth spending #40.00 for the bushing they show
and somehow enlarge the front support to hold it. Anyone been down this path yet? Just wondering if someone else has a better fix for this issue.
