Dave H (MI)
In the process of working down to the cylinders to see how bad things are. To recap, when I drained the oil pan the tractor had better than a half gallon of clear water in it with the oil floating on top. It had set outside with the hood on and a can bucket over the rain cap. Eventually found out the engine was stuck. I put some diesel in the spark plug holes to get it started and left it. In the meantime I pulled the cover off the rockers and found water all the way up there. Small amount of rust but it looks like the oil pump may have been siphoning water/oil before the rear seal went south. Based on this the decision was made to pull the head and have a look. Almost there but the manifold, with all nuts removed, doesn't want to come loose. If anyone has any guidance with this I will give it a try tomorrow. I managed not to break off any studs so far.
Curious where all that water came from on a tractor that lived in a locked barn probably 360 days of the year prior to the main seal going.
