Texasdeere
63 3010 Gas with a Zenith Carb. After I bought this tractor I dialed in the carb adjusted the throttle and everything was fine for a while. Now it still runs good with higher rpm or a load but the idle is a little rough. I turned in the idle mixture screw and the idle improved. The idle mix screw is all the way in and it is still idling a little rich. I did a complete rebuild with a kit and I have the same problem? Could the load needle be affecting the idle mixture? Should I look at the points, distributor? I just can't figure out how the idle can be too rich with the mixture needle all the way seated? It shouldn't even run this way!
Any Ideas?
Any Ideas?
