Have this White 4 80 17 backhoe 4x4. It has the Waukesha 6 cylinder diesel engine. I installed a 2000 watt external canister--KATS- Water heater to heat up the engine. It heats the water in the radiator, but not so much in the block if any.
Sitting on the tractor on the right side of the engine near the rear of the engine is a drain--that is where the inlet for the heater is hooked. The high side is near the front of the engine near the thermostat. These are the only two places where I can see to hook up the heater. All of the heat is going into the radiator--it appears.
This tractor is the industrial version of the Oliver 1650 or the 1655 with the WAUKESHA.
Thanks for any help......
