york
- Location
- Mechanicsville Va
The pump had a broken plunger I had it repaired, but when I installed the pump timed at 26 degrees BTDC as my serial number calls for, looking through the time hole on top of the pump housing the pointer and hub is lined up. The red tooth however is located one tooth before the pointer. I questioned the diesel pump repair shop on this and they said this was correct according to their manual. This tractor never ran out of power in 3rd or 4th gear at tractor pulls before the pump was repaired. Now it will run out of power in 3rd gear. Can this one tooth make a difference. It start OK with some white smoke for a minute or two.
