424 gas tractor missing under a pull
Anonymous-0
have a 424 that misses once warmed up under a pull...has fuel and have replaced the coil..can shift down a gear and it will be ok for a while but then when it heats up again it starts the stuttering again..will do this while removing snow sometimes also..have taken off the intake and exhaust manifold and see no gasket problems..any ideas..also anyone have a water pump for one of these tractors as mine has been welded on and while its down will try to replace...thanks
Have you checked the rotor & dist. cap?-- points & condenser?--plug wires & plugs?--timing? What heat range are the plugs?
Is the valve lash adjusted correctly? Valve lash tightens up as the engine warms up.
Just about bet it is an ignition issue rather than a carb. thing.
I think it has a fuel pump like my 276 ? it gave me a problem when under load {fuel starving] check fuel presure at pump . I am not sure what it should be. dealer or manual can tell you . hope this helps D F .
have replaced all the ignition within the last yr.. havent ran the valves in a long time... replaced fuel pump and then i ran line above carb so if pump quit it would gravity feed..there is enough gas to run tractor..thought i had a hole in the manifold as it was blowing heat out behind the carb so took manifold off and its just the 2 small drain holes so i guess ill plane it and reinstall and go from there..thanks for the input
