Anonymous-0
I have a 4240 that has started a strange problem. When running the baler, with the PTO engaged it will kick the PTO out of gear when you shift the Quad Range trans. Perhaps too low of hydraulic pressure?
The hyd oil and filter was changed at the start of baling, less than 50 hours on change. The valve bodies on the left side where the PTO shifter and clutch pressure were replaced at the same time....Help!!!! Thanks...Ts
