Anonymous-0
I've got a '71 4320 that has a vibration when running. I replaced the flywheel about 100 hours ago. at at that time i didn't notice any vibration. but in the last 40 hours or so i have noticed a vibration that was only present at low rpm's. but in the last few days it viberates all the time and i have developed a oil leak form the clutch inspection cover. the leak is trans fluid and not motor oil. My hunch is that i didn't get the trans input shaft into the piolt bearing/bushing when i reassembled the tractor and it has now took out whatever bearing and seal on the trans input shaft. hopfully it has not wrecked the input shaft yet. i have a shop manual and can see all the shafts and seals that may be affected. I have had this happen before on a 60's hotrod. Any one out there that could tell me if i'm bark'n up the right tree? maybe another idea that i'm not see'n. thanks for any ideas. TIM
