Derweibhai
Still tinkering with my SC, and can not get any oil flow to the rockers. I pulled the rocker shafts off and they are clean and no holes are plugged. I turned both shafts so the oil holes are oriented at about the 5 o'clock position with the holes facing the push rods. The oil line from the block had a crack in the top where the orifice is to shoot oil into the rod gallery. I had to fashion a new oil orifice out of brass and solder it in place, but the line is clear all the way down to where it attaches to the camshaft gallery. I changed the oil after flushing the block with about 5 gallons of stale gasoline I had which got a good amount of sludge out of the oil pan (but I have seen way worse). Replaced the oil with fresh 15/40 Rotella and 1/2 a bottle of Marvel. Still dont have a replacement oil filter as they are backordered at our local napa, but I hosed the one in it out with breakclean and reinstalled. There is good oil flow to the filter, and I get 18-20 pounds on the gauge immediately and it stays there (old gauge so dont know accuracy).
I am still waiting on my manuals to arrive, as this is my first Case in a long time. I did see a DC or CC manual page online that says they should have a drip every 5 seconds from each rocker after a 15 minute warmup. I have 0 flow at all from what I can tell, even after long observation with the cover off. Doesn't matter if I run higher rpm either, still no visible flow. I did pour oil on it myself, so that is a little distracting, but I see no movement of oil whatsoever.
I really want to work the tractor, and get her juices flowing, but without oil to the top end, I dont want to break anything.
