Texasmark1
Not a tractor but it's a Ford. Figured I'd get better coverage here. Just acquired a 9' 538 MOCO. This is a 1980-82 year model and I can't believe that I got the Owner's and Repair manuals with it....also the draw bar adapter, and 2 spare sickles in usable shape, rollers are 98% with good bearings and new tires. Having had JD and NH, this is a different machine and I like the design. Had the selling aftermarket dealer run it up and it is smooth and quiet. Wobble box is leaking a little oil which I will fix with Lubriplate 105 but is rugged and no slop in the drive. Seems the only thing I need to do is flush out the oil in the hyd. line, put new packing in the lift cylinders and replace the wobble box drive belt. The belt on the other side is 75%.
The lift cylinder parts list shows a Kit at the bottom of the list (H389270R1). I want to redo the "packing" and wonder if this Kit contains all the O rings and fabric packing that wears out needing replacing. Does the kit contain what is needed to do the job? The manuals show me how to get the cylinder out....was wondering that at the sellers place before I had time to look in the manuals.
Next the (drive ?) belt coming off the wobble box, or near it...haven't gotten too far into it yet, needs replacing (H567947R2). Seems that if I remove the chains and disconnect the wobble box from the sickle and frame bolts below, I can slip the belt under it to get it on. Yes no? Easier way?
As usual, comments appreciated.
Mark
Mark
