Bern
- Location
- Mount Vernon, WA
Anyone here with a 6000 with a 3-point that moves freely, as in you can pull the lift arms up by hand? Mine is so stuck I have to use a loader bucket to push the rear arms down. It takes so much force it squats the rear tires. I attempted to solve the problem today by removing the lift arms and pushing the shaft out a 10-ton porta power wouldnt budge it. Looks like Ill have to take the cover completely off the tractor and put it in a 50-ton press.
I noticed that Ford took the time to drill the lift housing for 1/4 pipe threads, and theres drillings which go to grooved bushings presumably for greasing. However, both top covers of mine have pipe plugs in the holes as shown. Service manual, owners manual, and parts book all show nothing. Anyone here put grease fittings in yours and did you get any grease pumped into them? The one cover I have I pulled apart and the groove was so full of crap theres no way grease would get in there if I tried.
