Hello,
I have a question about why no hydraulic pressure on our 656 Farmall? I was putting out hay for the cows and picked up a bale & put it in the ring. Then I back up to the shed to run a couple cows out and when I went to get off, I dropped the loader down on the ground to act as a E-brake (not enough to raise the front end, just down on the ground). When I got back on, I couldn't raise the loader. It wouldn't budge, like it had no pressure. I figured maybe a relief valve as I had trouble with it a few years ago. I took it apart, nothing wrong there. I pulled the 3 point plate to look back there in the rear end and I see circulation, but I haven't drain the rear to check the hose. I put a gauge on the remotes and it reads 0 PSI. I have no loader, no rear remotes, no 3 point and no steering. The pump was replaced 2 or 3 years ago and everything has been working good up until now. Any suggestions? Thanks in advance!
