672 transplant
yes, only issue is the hole in the left front side of the block where the steering rod on the 30 series goes tru I put one in a 1030 tom in ky
(quoted from post at 16:33:30 01/29/15) Will a 2870 engine bolt up to an eight speed bellhousing/
So let me get this straight, you're gonna bolt an 11L Scaania into a 30 series?? Please tell me that comes with copious amount of pictures and a video :D
I am hoping it will. I want to farm stock pull it. I think this would be like JD 619 transplant into the 6030s.
(quoted from post at 17:04:38 01/29/15) yes, only issue is the hole in the left front side of the block where the steering rod on the 30 series goes tru I put one in a 1030 tom in ky
Tom, that sounds really neat, can you post pictures?
Mel.
Hi Sounds like an interesting project, i Do kinda wonder about the rules for it with that motor, and if anybody will actually let this tractor run in classes other than modified.
The other possibility is they turn a blind eye till you win something, then all the whiners and complainers start. Then you got to go modified class or like they did with 2 high hp tractors round here, It's a "demo Pull" as those 2 could beat everything else in the regular tractor classes. As long as they started and hooked to the sled .
If you do it I would like to see the pictures as well. Thanks
Regards Robert
