Hi all, new here. I recently bought an old ford 5500. Im looking for info on the exact year and some other specifics Im hopoing to find.
number on right side engine header is E6NN9425BC 1, and V033682
numbers on other side block are FO ?? 6015-CB and seperately HH3 4 k 24
Supposedly this tractor has a newer factory engine with less than 100 hrs.
So far Ive changed out 7 hydraulic hoses that were bad, drained the hydraulic reservoirs and dug out some real nasty gunk from the bottom.
changed engine oil and trans fluid as well.
i bought 70 gallons of multi use fluid for the whole tractor. I still need to flush the trans again the fluid looked like white elmers glue and the engine oil was a grey sludge.
the wire harness is fried. it looks like it was in the charging circuit because on the back of the amps meter, both wires are toast leading both directions back towards ignition switch. I think i can just do some rudimentary wiring to get the gauges and lights that i would want. any problem with that? Probably Ill just hookup temp sensors and pressure and maybe a light.
so back to the fluid...now with new fluid when i operate the loader i hear a groaning and fluid in reservoir is foamy. wheres the most likely place to draw air into that circuit? The hoe doesnt groan or make noise.
Thanks for any help.
