Shane Hansen
hey y'all I have a 730 JD tractor that the customer says his batteries won't keep charged and his amprrature gauge quit working so I found a deal online to see if its the voltage regulator or the grnerator. it said put jumper on batt and gen terminal on voltage reg. momentarily jump it then put jumper on a2 and field terminal on the gen and the volt meter test leads on a2 and a1 terminals and then polo prize the voltage reg start tractor and then see if you get 28vs or greater well he's sitting at 20v or 21 so I looked at brushes looked worn not bad but put new in then checked.the communator bars for community.and was OK checked the brush for touching case was good checked fields and was good put back on and still back to what I was before .... anyways would it be the voltage regulator ? and he has a 24v system any help word be great thanks
