730 JD charging question
Shane Hansen
hey y'all I have a 730 JD tractor that the customer says his batteries won't keep charged and his amprrature gauge quit working so I found a deal online to see if its the voltage regulator or the grnerator. it said put jumper on batt and gen terminal on voltage reg. momentarily jump it then put jumper on a2 and field terminal on the gen and the volt meter test leads on a2 and a1 terminals and then polo prize the voltage reg start tractor and then see if you get 28vs or greater well he's sitting at 20v or 21 so I looked at brushes looked worn not bad but put new in then checked.the communator bars for community.and was OK checked the brush for touching case was good checked fields and was good put back on and still back to what I was before .... anyways would it be the voltage regulator ? and he has a 24v system any help word be great thanks ;)
I"m pretty certain that "a deal online" that you found is not correct information.
These 24 volt systems are difficult to troubleshoot and repair.
Are you savvy with electrical repairs ?? If not, I would stay away from those systems. If you are savvy, then proceed with caution as the 24 volts "floats", which means it's not using the tractor chassis as a common point.
I have asked reputable sources within John Deere if there is (or was) a service information for the 24 volt systems. So far no one has been able to find such info for me.
All -12V and +12V devices use the chassis as the return path. Contrary to what a resident history prof thinks. The 24V gen, 24V regulator and 24V starter have NO path through chassis.
oh well ok so they just put a + for positive side for wire and then a - for a wire ? just a circuit within it self with it not touching the chassis ?
