Scottymudguy
60' 801...
Drained & cleaned out sump, re-built pump, replaced ring & backing ring on cylinder piston, replaced the position control shaft (Thanks to Mr. John Smith!! Who happened to have one.)Re-assembled everything & re-installed lift cover...ok sounds pretty straight forward to here right? Now lets go around the bend....
Fire the tractor up, warm it up good because its pretty chilly here in N.Nevada right now! When the hydraulic's come to life FINALLY...the arms come up....and stay up, not even after tractor is turned off can I get them to go down....put position lever down & stood on the arm's...nope aint going nowhere!
So off comes the cover again..this time with a hoist & a strap to keep her level...much easier!!
At first the cylinder piston still would not go back in, I ran a little air through the pump pressure side & finally got things moving...I'm not sure if I was "air locked" or if it was a slug of cold hyd fluid that just plain 'ol wasnt going anywhere! Anyone have thought's or experince like this? Next up...all this stuff is over the course of not quite 2 weeks...in the midst of all of it I had found links for Zane & his Thang!! Contacted him, he sent goodies & off to hydraulic adventure land I went.
So yesterday was when the cover had come back off & the whole cylinder piston thing takes place ( I was just dang glad that there was nuttin busted, broke, tweaked, ------ away..etc).
After I had my arms freed back up I went on to adjusting the linkages with Zanes materials & info..no problem, it went really smooth, quick, & easy...I would say under a half hour...& I was taking my time being very cautiuos & double checking everything. I wanted to ensure I had not missed or skipped nothing you know!!
So after all said & done, I put a little air to 'er to test things out...for some reason my position control lever has no bearing on what the arms are doing. Lever down, air, arms go straight to the top without me even touching the lever...Bled everything off (I clamped a rag over the return side hole to free up a hand...that worked great)& reset the arms back down, & tried holding them down this time while putting the air to it...nope aint no way, would have picked me up if I had both hands on 'em! So in streak of brilliance...I think "huh, my lever is "backwards"". So I moved the lever up and ran through everything again &......Got the same results...no diffrence!
Draft lever is in postion control the entire time during this by the way! Tried draft mode....same!!! Had to quit...thought about trying some reverse barley-pop engineering on it...probably a good thing I didnt, because a big hammer usually finds it's way into the scenario....
So questions I have..
1) Anybody have the "locked up" Cylinder piston like I described, before?
2) Is it possible I have linkages or shafts backwards? It all works smoothley & free, looks to me like the pic's I have seen of them
3) Valves or something stuck, or tore up inside the side of the lift cylinder?
Better take some Migrane stuff this morning....ey,yi, yi!!!
Scott
Scott
