806 shift cam
bv
A friend of mine has a 806 that broke the shift cam that’s under the top plate so they removed the top cover to replace the shift cam and then couldn’t get the top transmission plate all the way down because I’m assuming the reverse rod came out of the reverse fork so 2 different people have told him the tractor will have to be split to fix, now I have never worked on one of these before but from what I’ve studied it shouldn’t have to be split to fix the problem, what is your opinion of what it would take to fix this tractor, it was running great and then he got it stuck so thats all I know
Your talking about the hi /lo/n/ rev. Yep when you jump into them ya FIRST remove the side cover there behind the left step , if the hyd oil level is at the full mark you will loose about a gallon . This is where the rev. shift fork lays and the in you lift that top cover that fork tips away and most times the small key falls out . Just had mine down with a broken Hi LOW SHIFTING FORK . Ya also have to have the shifting fork just right to drop into the cam slot and some body lining up the reverse shifting fork and make sure the woodwroff key does not fall out . If the key fits loose in the shifter road then you had best replace the shifter rod as you will be slamming the shifter to get it into reverse. . On the 06's a little slop here a little slop there and you have issues getting into rev. . Next up is a full clutch , trans bake and MCV DUMP VALVE adjustment to top off better shifting
