LaBoyteaux
Just purchased an 830. I've owned two previous CASE-O-MATIC, a 410B and a 530. The torque converter always unlocks when the clutch pedal
(pressure dump) is depressed. This 830 will not do that. Otherwise, the torque converter operates normally, will lock and unlock manually, pressure in the green on the gauge. On the 410B and the 530 there is some mechanical linkage that pushes the lever to the unlocked position when the pedal is depressed. I don't see any mechanical linkage that would do that on the 830. What am I missing here?
