mopar66701
i have this 830 problem case. has an intermittent and apparently random misfire at any engine speed cold or hot. mainly indicated by that weathercap flapping clattering around .during the process of rebuilding this thing to put back to use i have installed all new ignition parts, rebuilt carb, the heads were supposedly redone prior to me buying it however everything the prior owners did i have had to go back and redo. they claimed they were checked and reworked blah blah blah. i can say that looking through the sparkplug holes the cylinders have hone marks on them and the valve margins look pretty thick too. checked for combustion gas in cooling system as i was worried they had a poor headgasket installation. has 150 psi compression on all cyl. less than 25% leakage past the rings on all. (measured cold) fires right up at the tap of the key. ignition scope didnt really help narrow this down any at all. im thinking the previous owners may have set the valves too tight or something. or maybe the valve springs are iffy. what do you think. anybody?
