steve-in-ga
Thanks for all the things to check. I've performed all the checks to determine if the miss is in the ignition side and haven't found a culprit yet. No fire bouncing around at night. I jumped around the ignition switch and ammeter. I connected a timing light to each plug wire and don't see a miss. The spark is not weak at any plug.
I do have a very slight amount of play in the distributer bushing.
I was telling my friend about the issue and he was telling me about a test to see if an issue is in the valves. He said to hold the corner of a piece of paper up to the tail pipe and see if there is any sucking at the tail pipe. When I performed this test, before the miss, the paper is sucked into the tail pipe instead of blowing away. I checked the valve clearance with the engine off and cold and each valve (intake and exhaust) was set to roughly .015. What could be causing this? Sticking valve, weak or loose spring?
thanks
-steve
thanks
-steve
