Silver Eagle
8N D. Looks like the serial numbers are above it. I ll have to work on that a little bit to make them out.
(quoted from post at 20:20:44 07/21/23) 8N D. Looks like the serial numbers are above it. I ll have to work on that a little bit to make them out.
Sorry for the delay, but I think this is what you re looking for. I believe it s a 9n. with 8N motor possibly. Sending some pictures now I m not getting up I m done no be quiet so I get done on this phone. Darn could that be at 43?(reply to post at 16:41:15 07/21/23)
(quoted from post at 18:36:18 07/21/23) The serial number on that lift arm is 9N 543
(quoted from post at 23:28:20 07/21/23) Between the old filter and the starter and below head there is a plate but the numbers are completely gone if that is the location
(quoted from post at 05:41:10 07/22/23) The tractor in the photo is a 9N or 2N. It is not an 8N.
The Sherman auxiliary transmission is an OD/direct only.
(quoted from post at 12:13:09 07/22/23) Sounds like I definitely need to replace the clutch then regardless will all the 8-2-9 N tractors have the same Clutch and pressure plate kits or will the 8N be different? I assume when I order I need to have a 9 inch heavy duty kit Thanks again to everyone.
