Thanks to all the help from everyone on my previous post on getting my tractor started.
Now I have another issue.
I just put a new coil on with points condensor, new spark plug wires, etc the works.
Got it running immediately after I assembled it.
I put it up in the barn/shed, turned off the key, disconnected both leads to the battery, turned off the fuel shut off and went in.
Came out today to start it, connected battery, turned on fuel, turned on key, proceeded to start.
well it turned over and won't fire. Tested for spark at the plugs, none, great.
Took coil off and tested it. I get a reading from the top post to the pigly tail but not to the other point. Nothing.
I shall assume the coil is toast as that is why I replaced it.
My question is :
How did this happen? How can I prevent ruining a coil every time I run it?
8n 1948
Thinking outloud now...
I have the ceramic fuse inline before the coil, do I need it? Is that the problem?
My question is :
8n 1948
