8n hydraulic pump
Anonymous-0
working on a tractor for neighbor power lift moves slow checked hyd press on pump less than 100# is the pump worth rebuilding or just get a working used one
Before you change out the pump you might try replacing the relief valve. My first tractor was an 8N and that was the cure for the same problem. It's easy to do and much cheaper. PK
