Roger in Iowa
Is it stored inside ?
Or at least covered?Is it stored inside ?
I go through a lot of hydraulic dipsticks. I must keep hitting them with my heel and the top portion breaks off.It will be stored inside a gravel floored enclosed lean to attached to the barn where it’s been for the last 15 years. I’ll probably throw a couple of old sheets over it. Shifter boot is good but the hydraulic dip stick needs to be replaced.
Old motor cycle wisdom: Do not cover the tractor directly with a tarp or any other water proof material. Your moisture isssue will be worse. Sounds like you have a good plan. Keep it under the leanto to keep the rain off it and cover it with a material that is not water proof that allows moisture to evaporate. Internal moisture is unavoidable. Best thing to do is run the tractor frequently!It will be stored inside a gravel floored enclosed lean to attached to the barn where it’s been for the last 15 years. I’ll probably throw a couple of old sheets over it. Shifter boot is good but the hydraulic dip stick needs to be replaced.
Nothing is going on. Its working exactly as designed.My hydraulic pump will raise, and lower the blade on the rear but when I try to grade rock the blade wants to ride up and over. Any idea what is going on?
Then why won't it stay down and gradeNothing is going on. Its working exactly as designed.
TOH
The 3pt floats and the only thing holding the blade down is the weight of the implement. Thats simply the way it works.Then why won't it stay down and grade
Okay. ThanksThe 3pt floats and the only thing holding the blade down is the weight of the implement. Thats simply the way it works.
Try adding some weight to the blade.
TOH
I welded a bracket on to my back blade for my set of suitcase weights. Now works great grading gravel.Okay. Thanks
I have a 2N, but the adjustment for the main control spring appears to be the same for both the 2N and 8N.My hydraulic pump will raise, and lower the blade on the rear but when I try to grade rock the blade wants to ride up and over. Any idea what is going on?
It is under roof. Never out in open. I haven't started it since early fall because I have a rotator cuff tear. I did use it late summer. I will try to get charger on batteryIs it stored inside ?
