Loren, Read your comment on Ol'TinBender's post. I didn't want to hi-jack his post by adding this there.
I don't have the original Case shaft with a spline on each end. I think the hub is original though.
I had a new spline end matching the hub welded on to the shaft. They did a socket weld. Crappy looking but would have been functional if I had intended to use it.
13 splines 7/8" dia. If that matches your shaft, all we need is the bolt circle of the hub right?
In any event you should be able to get a shaft made up. The machine shop that did mine had a big assortment of spline stock, unfortunately they went out of business a couple of years ago.
Looks like Ol'TinBender has 6 splines, can't really tell on yours.
I'll check the hub over the weekend and make sure it is as good as I remember it.
Joe
Joe
