I've seen some kits to add remotes to a MF65. Just wondering two questions.
1. Do you need to add additional fluid to the tran/diff to make up for the fluid in use with the hydraulics?
2. Since the fluid in the tran/diff is GL-1, will that still work for hydraulics? Should I switch to tractor hydraulic fluid or is that a bad idea? I know the diff may or may not have brass bushings which is why GL-1 is supposed to be used.
