Charles, NO they typically are NOT the same thing.........I would suggest replacing with a capacitor of the same rating (Uf and voltage)
regardless of what it may be called. What you describe makes me think the problem may be EITHER A capacitor orrrrrrrrrrr A start
winding,,,,,,,orrrrrrrr A centrifugal start switch problem, yet due to the capacitor you show obviously more like a capacitor problem, try
that FIRST
In a typical single phase split phase motor........... If everything is in place and working correctly a START capacitor (If so equipped)
and start winding are both in place ONLY TEMPORARY for start up until such time the centrifugal switch opens taking BOTH out of the
circuit. If they were to remain in place and it had a START capacitor (say the centrifugal switch failed to open) it and the start winding
could overheat and be damaged. If the centrifugal switch failed to ever close any START capacitor (if so equipped) or start winding
wouldnt be in place and the motor would sit there and hum and not start until you manually gave it a good spin in either direction.
Ive seen non capacitor single phase motors, capacitor start motors, capacitor start and capacitor run motors, capacitor run but I hesitate
to say from here what you have.......
Heres is a good place to get help and purchase motor capacitors or other related equipment
https://www.grainger.com/?gucid=N:N
S
aid:MS:CSM-
2296:8DK268:20500731&ef_id=973438806bc617920ad75858166520fe:G:s&s_kwcid=AL!2966!10!79508582020848!62050107369&gclid=973438806bc617920ad7585
8166520fe&gclsrc=3p.ds&msclkid=973438806bc617920ad75858166520fe
DISCLAIMER its been yearssssssssss since I was an Electrical Engineer at the Century Electric Motor Company so noooooooooooo warranty on
any of this, things have changed......
Best wishes be safe be happy
John T
Graingers
