old
- Location
- Camdenton Missouri
Finally had some one send me an e-mail that truly explained thing in terms that where correct. Very simple math problem answered the question correctly. 3HP motor draws more then the tagged 15 amps plus add age of it to the equation amp draw was close to more then the 20amp break could handle. If I had a clap on amp meter I would have known that from the get go but I do not own one.
I installed a 30 amp breaker and it is still turned on and working.
Now to the new problem. So far it has pumped up to 40PSI and shuts down. Seems that the regulator is not working as it should be. So I am letting it run some to see if it might just be sticking due to not be used in a long time. If that does not fix it I'll install a new pressure switch and be done with if
