Keith Williams
- Location
- Wellsville, Ohio
Ford tractor friends,
I went to pull my 1964 4000 Gas out of it's winter napping place and it would not start.
Here is the story of what I found.
Engine would turn over but would not start. I had started it several times this winter, but it would not fire this time.
No spark at plugs. I pulled the cap, dust cover and ran a piece of paper thru the points (this has helped in the past).
Still no spark. I manually rotated engine until points were closed and manually opened them, no spark. Never had that before.
I came home and read and thought, went back to farm with the meter. (This tractor has been 12 volts for almost 40 years)
With points OPEN I read 12.6 at battery, around 8 volts on + side of coil, around 6 Volts on - of coil, same on side of distributor.
Inside distributor was all wacked out! The points had a low voltage reading and even the plate where the points mount had like .3 volt reading.
Long story but the problem I found was a broken insulator on the bolt thru the distributor case on the inside. I had a short to the distributor case.
I put a piece of plastic container on the bolt head and that solved the problem. I had never had the distributor that far apart before.
I just saw a post about a Jubilee not starting and that prompted me to write this up.
I have seen several posts asking what the voltage reading should be and I wanted to post what readings I had in a NO START Situation. Thinking this could help someone if they saw similar readings.
Keith Williams
Keith Williams
