I have an issue with my 200, I was out disking a field and after about 15 minutes I noticed it was like I had the clutch in, I shift from high range to low and it took off, but after about 10 more minutes the same thing happened, I raised the disk let it idle for a few minutes and made my way back to the garage.
All fluids are fine.
Could this be an issue with an adjustment on the high/low range?
One other note, don't use this tractor in winter so it sat, when I got it running I noticed I was having a little trouble shifting like the clutch wasn't engaged all the way, could this be a clutch issue?
Thanks in advance guys
