Hello to all, I have a B that will only run at 3/4 throttle and barely runs, it will sputter and sound as if it is missing on one or more cylinders, it has a new manifold, rebuilt mag, carb is rebuilt
(and set to specs from the manual), valves have been adjusted to the proper specs and I am trying to figure out what else it could be, timing was verified and the carb settings should allow for a start
but takes quite a bit of cranking to do so. I've tried leaning it out and richening the fuel mixture and no notable gain in running. I was curious if anyone else has had a similar issue and if so what
should I look at. I pondered on the idea that it could be something to do with the governor but I would prefer to not dive too deep into it if its not a necessity.
Any help is appreciated thank you in advance.
