Hi all. Just joining the forum today and this is my first post.
Today I picked up what I have been told is a 411b with a loader attachment. It has power assist and 3 point hitch. The serial tag reads 411b. Although I see the faint marking on the hood reading 400?
The previous owner says that the transmission fluid is entering the rear end and overflowing thru the axle breather under the seat. He used hydraulic fluid for the transmission. From my reading that is incorrect fluid. What should be used? Also does the loader attachment use the same oil supply from the transmission?
The engine starts easily and seems ok. Although I suspect that it may be low on power because when in 4th gear and I put it in direct drive the engine dies and has to be switched back to caseomatic. Or someone think this could be transmission related?
I have a ton of questions but ill leave this here for now. In the mean while, thanks in advance.
Adam from pennsylvania.[size=7:4227015750][/size:4227015750]
