another antenna question
banjo
Ok, i've done the search on which antenna i'm going to need for my area. went to the antennaweb.org site and all it says is i need a violet rating antenna.
Plus i did the search for the channels i should receive for my location.It shows 1 channel(pbs).
Now i know for a fact i was getting a channel 150 miles away with the analog signal. But that channel has gone digital and i cant get it anymore.
Now at times i can get 4 other analog stations that hav'nt gone digital yet with my old antenna.
So if i buy a new antenna what are the odds i'll even get any stations other than the PBS station i can get with my old antenna and converter.
Also the channels i was getting are in the 2-13 range. I'm 80-150 miles from them. plus all the hilly terrain and mountains between us.
All the antenna i've looked at online do not give a color rating or how far they are supposed to pull signals from.
I just hate to waste 150 dollars and still not receive any channels. It would be nice if the channel search listed more than just the 1 channel so i would feel better about maybe needing a new antenna.
Of course no one in this area that i know still uses an antenna. they all want satellite. And cable is not availabe.
I'm with you Banjo. I have satellite on two tv's, but I like having the on-air antenna for bad weather when the satellite quits working, so I've got a separate tv with the antenna. I've had the same problems you're having, and I'm looking at those $150.00 antenna ads on websites. But I still wonder how much better off I'm going to be with one of those.
Butch
Hi banjo,
I have 1997 bat-wing RV antenna that I use with a indoor signal booster and receive great HDTV at about 60miles away.
Without the signal booster, no HDTV. And the booster is also a 97 model.
If your using a signal booster then try massaging the on/off or gain switch and see if that helps.
T_Bone
If you would go out and buy a new TV with a digital tuner for $400-$500.00 you would not need the converter box, and probably get by with your old antenna. If you go satelite, it will cost you $40.00-50.00 a month for the basic package. Doesn't take long to pay for a new TV.
If it isn't a ultra deep fringe channels 7-52 antenna. With a antenna mounted amp, antenna mounted FM pre-filter prior to the amp, a rotor, low loss RG-6 or RG-11 cable and dry connections. And a quality dtv converter or dtv ready tv,forget it.
Reception will also vary with transmitter power and the shape of their signal pattern.
Depending on the weather I have eight channels that vary from full clarity to only snow. Five others that usually come in.
This is a very good antenna and a lot less than $150. Some assembly required, but not real tough.
If one doesn't pull in a strong enough signal, you can stack a couple on the same mast, then use a pre-amp (mounted on the mast). If you can't get it then, you probably never will, short of having a very tall mast.
db8
If you have a good antenna that you used on VHF/UHF analog chanels, There is no reason to buy a new one , But you might have to buy a new booster as the upper chanels ar higher than the older ones. That means you will have trouble getting them at,Their in the same range as celler phones so range will almost be "LINE OF SIGHT". The feds just can't leave things that work alone the hole idea iis to open more air space so they can sell to commercel operators.
The channels taken are the highest frequencies, 52-69,70-83 & 84-114. They tend to travel in a straight line only. vs The lowest channel 2-6 in particular and 7-13 to a degree.
Hi TG,
I've read about those, and they look like they should work well for me. Will they pick up VHF as well as UHF? How far below the antenna on the mast can I mount the pre-amplifier? Is 10' too far?
Butch
Hi Jim,
The correct name is a TV signal amplifier and you can buy them at any TV parts supply including Radio Shack.
Some work better than others and it's a trial and error method of choosing one some times.
T_Bone
It is not optimized for VHF, but the one I installed picked up VHF OK... and from the back side at that. The higher the VHF channel, the better.
I used a preamp from Radio Shack, I think it came with a short length (about 6') that I used on the antenna side. The idea is to get close to the antenna to amplify only the signal and not noise captured by the cable.
Use coax for everything, also.
Go to Dennys Antenna. He has a tremendous amount of info available. His prices are a little high, butyou can return items if not satisified. He was a great help to me. rebojo
not anymore. i never was much good anyway. messed up my elbow and never could get the rythum back.
I went to that web site and tried e-mail. he never did answer it. i tried to call but only got a recording with no way to leave a message.
I've got a TT that used to get more channels then my antenna for the house. I'll try to get it close to some elec and see if the converter picks up anything with it.it has a booster also .At least it is worth a shot to see if by chance it might pick up some more stations.
The amplifier is to be mounted 30-40ft up in the air with the antenna. And the amplifiers power supply box mounted down at the tv or dtv tuner.
The one piece amps are only good for boosting signal before a splitter to supply several tv's. Trying to amp the signal from the antenna at the tv instead of up on the antenna just amplifies noise.
The antenna for DTV needs to receive channels 7 through 63. Channels 2 through 6 are the portion of the spectrum the FCC has removed from Television service, and is now "supposed" to be used for Law enforcement and emergency services (ambulances and civil defense etc) If your present antenna does a good job on channels 7 through 63 you don't need a new antenna.
This site will show you the "reception area of each channel before and after the change. http://www.fcc.gov/mb/engineering/maps/
Acording to antenneaweb I should be getting 1 channel analog, and 1 channel digital. If I raise my antennea to 2000 feet, it still will only show a couple more channels.....
According to the maps from other sites, again 1 channel either way.
What I actually get om my antennea 15 foot pole on top of the roof:
About 10 analog channels, over 50% of the time.
About 12 digital signals, 3 of them 75% of the time, others about 1/2 50% of the time, and the other 1/2 25% of the time. Weather, sun angle, and tree leaves all play a role.....
Come June, everything will change. Most channels 7-13 will return to VHF from their temp broadcast in the UHF range. Power will be boosted for most of them, tho how much that helps isn't really known.
UHF channels don't travel quite as far or as well through obsticals as VHF did, so distance matters. Line of sight is more important with digital than it was with analog, soa taller antennea might be needed.
Analog was pretty forgiving if you did not have the big directional antennea aimed at the station. Digital will break up & 'reflect' a lot more if you are not aimed right dead on the station. (This is an issue for those of us in the fringe areas, who could get stations from different directions depending on the weather - now it's real hard to pick off a strong signal if you can't rotate the antennea to face the channel.)
Clear as mud, right?
--->Paul
The noise floor must be very, very low in your area. The tv signal maybe weak but the noise is so low the signal can still be heard. Like a whisper across a silent hardwood floored room.
Around here the noise floor is so high. It's like being in a noisy bar and you can't hear the person beside you yelling in your ear.
I dont need dish for my entertainment. I just want the closet channel for weather. But being my local channel for severe weather is 150 miles away. Youd starve on what i make.
