Yesterday I picked up a David Brown 990 and I would like some help identifying the loader so I can get a bucket for it. It looks like it has been modified from single to dual tilt cylinders. I cannot find any model or serial numbers on it.
It's heavily modified. Even the original bucket might not fit any longer.Yesterday I picked up a David Brown 990 and I would like some help identifying the loader so I can get a bucket for it. It looks like it has been modified from single to dual tilt cylinders. I cannot find any model or serial numbers on it.
Can you expand on that please?It's heavily modified. Even the original bucket might not fit any longer.
That loader did not originally have tilt cylinders for the bucket. It was what's called a trip bucket, where you pulled a lever that released a catch that caused the bucket to dump. The bucket style is very different from one that uses tilt cylinders to dump.Can you expand on that please?
Good to know, thanks!That loader did not originally have tilt cylinders for the bucket. It was what's called a trip bucket, where you pulled a lever that released a catch that caused the bucket to dump. The bucket style is very different from one that uses tilt cylinders to dump.
Honestly you're not going to be able to buy a bucket "for" that loader. You will need to have one made or modified to fit. For that, the brand and model of the loader is meaningless. The fabricator that will be making/modifying the bucket will want measurements. Such as, distance between the loader arms, width of the loader arms, pin diameter, distance between the lower boom pins and cylinder pins, and possibly other measurements.
John Deere? This is a link to the old parts book. To see if they still carry them you need to transfer the PNs into the “New” parts book. And FYI if you put them in the cart in the old parts book they will be dumped when you transition to the new one. These diagrams aren’t in the new book. PIA. JD 37 loaderYeah the cantilevered pin surprised me also.
Any thoughts on where to find a cylinder rebuild kit for the lift cylinders?
Thank you!John Deere? This is a link to the old parts book. To see if they still carry them you need to transfer the PNs into the “New” parts book. And FYI if you put them in the cart in the old parts book they will be dumped when you transition to the new one. These diagrams aren’t in the new book. PIA. JD 37 loader
Other options, Baum Iron or local hydraulic repair shop.
Barnyard covered it for me!Good to know, thanks!
That worked great! Found a parts diagram and got all the parts on order for $60. Seems reasonablish.John Deere? This is a link to the old parts book. To see if they still carry them you need to transfer the PNs into the “New” parts book. And FYI if you put them in the cart in the old parts book they will be dumped when you transition to the new one. These diagrams aren’t in the new book. PIA. JD 37 loader
Good thing I've got both of those!You likely wont find a bucket to fit that loader. Best you can do is just find a bucket roughly the right size and get out the torch and welder.
Just for future reference, you can take the cylinder apart and take it to your local hydraulic shop and likely get a kit for half that price.That worked great! Found a parts diagram and got all the parts on order for $60. Seems reasonablish.
I built a Westendorf quick attach one time. Honestly though, for the time I had in it I would have probably been better off to just buy. I do still make the Westendorf quick attach piece that goes on the attachment, they are easy with just a piece of angle and a plate on top and bottom with a hole.Thanks. Looks close. On mine the lift cylinders pin on the outside of the towers but maybe that's not right. Any resources for building a quick attach?
Just don’t expect too much out of it. Those loaders weren’t all that strong and it doesn’t look mounted the best. Moving hay and scooping loose material should be fine, but you go to digging dirt and stumps you’ll likely have problems.Good thing I've got both of those!
